The THS7700 is a wideband, fully differential amplifier for high speed signal chain and data-acquisition systems. The THS7700 will operate on a single +5V supply. It has been optimized as a 16-bit analog-to-digital (ADC) driver and provides high bandwidth, low distortion and low noise. The THS7700 is ideally suited for high speed data acquisition systems that require very high dynamic range such wireless base station signal chain applications. THS7700 offers very fast recovery from overdrive conditions and also contains a power-down bit that can be used to place the device in a power-down mode. The THS7700 is offered in a QFN-24 package.
