LT1374 pdf datasheet (4.5A, 50
消耗积分:5 | 格式:rar | 大小:666 | 2008-09-27
时见栖鸦
分享资料个
LT1374 pdf datasheet (4.5A, 500kHz Step-Down Switching Regulator)
The LT®1374 is a 500kHz monolithic buck mode switching
regulator. A 4.5A switch is included on the die along with
all the necessary oscillator, control and logic circuitry. High
switching frequency allows a considerable reduction in the
size of external components. The topology is current mode
for fast transient response and good loop stability. Both
fixed output voltage and adjustable parts are available.
A special high speed bipolar process and new design techniques
achieve high efficiency at high switching frequency.
Efficiency is maintained over a wide output current range
by using the output to bias the circuitry and by utilizing a
supply boost capacitor to saturate the power switch.
The LT1374 is available in standard 7-pin DD, TO-220, fused
lead SO-8 and 16-pin exposed pad TSSOP packages. Full
cycle-by-cycle short-circuit protection and thermal shutdown
are provided. Standard surface mount external parts
may be used, including the inductor and capacitors. There
is the optional function of shutdown or synchronization. A
shutdown signal reduces supply current to 20mA. Synchronization
allows an external logic level signal to increase the
internal oscillator from 580kHz to 1MHz.
评论(0)
发评论
下载排行榜
