TPS2421-1,TPS2421-2,pdf(3-V to
消耗积分:2 | 格式:rar | 大小:1295 | 2010-10-28
贾伟刚
分享资料个
The TPS2421 provides highly integrated hot swap power management and superior protection in applications where the load is powered by voltages between 3.0 V and 20 V. These devices are very effective in systems where a voltage bus must be protected to prevent shorts from interrupting or damaging the unit. The TPS2421 is an easy to use devices in an 8-pin PowerPad™ SO-8 package.
The TPS2421 has multiple programmable protection features. Load protection is accomplished by a non-current limiting fault threshold, a hard current limit, and a fault timer. The current dual thresholds allow the system to draw short high current pulses, while the fault timer is running, without causing a voltage droop at the load.
评论(0)
发评论
下载排行榜
