TPS2211,PDF(Single-Shot PC Car
消耗积分:2 | 格式:rar | 大小:524 | 2010-10-30
李鸿洋
分享资料个
The TPS2211 PC Card power-interface switch provides an integrated power-management solution for a single PC Card. All of the discrete power MOSFETs, a logic section, current limiting, and thermal protection for PC Card control are combined on a single integrated circuit, using the Texas Instruments LinBiCMOS™ process. The circuit allows the distribution of 3.3-V, 5-V, and/or 12-V card power, and is compatible with many PCMCIA controllers. The current-limiting feature eliminates the need for fuses, which reduces component count and improves reliability. Current-limit reporting can help the user isolate a system fault to the PC Card.
The TPS2211 features a 3.3-V low-voltage mode that allows for 3.3-V switching without the need for 5 V.
评论(0)
发评论
下载排行榜
