TPS65180,TPS65181,TPS65180B,TP
消耗积分:5 | 格式:rar | 大小:1031 | 2010-11-04
duke刘
分享资料个
The TPS65180/TPS65181 and TPS65180B/TPS65181B family of devices are single-chip power supplies designed to for E Ink® Vizplex™ displays used in portable e-reader applications and support panel sizes up to 9.7 inches. Two high efficiency DC/DC boost converters generate ±17-V rails which are boosted to 22 V and –20 V by two change pumps to provide the gate driver supply for the Vizplex™ panel. Two tracking LDOs create the ±15-V source driver supplies which support up to 120-mA of output current. All rails are adjustable through the I2C interface to accommodate specific panel requirements.
Accurate back-plane biasing is provided by a linear amplifier and can be adjusted either by an external resistor or the I2C interface.
评论(0)
发评论
下载排行榜
