PTB48600A,pdf(85-W 48-V Input
消耗积分:3 | 格式:rar | 大小:392 | 2010-11-12
贾飞小
分享资料个
The PTB48600A is one of a series of isolated DC/DC converter modules that provide a pair of complementary supply voltages for powering line-driver ICs in xDSL telecom applications. These modules operate from a standard telecom (-48 V) central office supply and can provide up to a 85 W of power in a balanced load configuration.
The A-suffix module (±5 V) is designed to power the line driver ICs for the AC-7 ADSL chipset. It will also power any other applications that require a complementary supply with relatively balanced loads. The two compliementary outputs can also be configured as a single output of twice the voltage magnitude. As an example, the outputs of a PTB48600A can be adjusted up to ±6 V, and configured as a single 12-V output.
评论(0)
发评论
下载排行榜
