PT78NR212,pdf(10-12W Plus to M
消耗积分:2 | 格式:rar | 大小:433 | 2010-11-18
王兰
分享资料个
The PT78NR200 series creates negative output voltage from a positive input voltage greater than 9V. These easy-to-use, 3-terminal, Integrated Switching Regulator (ISRs) have maximum output power of 10 to 12 watts and a negative output voltage that is laser trimmed. They also have excellent line and load regulation.
The PT78NR200 requires 100 LFM of airflow at its maximum output current.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
