PT78NR206,pdf(10-12W Plus to M
消耗积分:3 | 格式:rar | 大小:433 | 2010-11-18
分享资料个
The PT78NR200 series creates negative output voltage from a positive input voltage greater than 9V. These easy-to-use, 3-terminal, Integrated Switching Regulator (ISRs) have maximum output power of 10 to 12 watts and a negative output voltage that is laser trimmed. They also have excellent line and load regulation.
The PT78NR200 requires 100 LFM of airflow at its maximum output current.
评论(0)
发评论
下载排行榜
