MICRF005芯片是Micrel公司生产的一种高速无线UHF收发器?熏是一款单芯片OOK收发器,可用于远距离低功率无线设备中单向和双向无线连接。MICRF005采用“天线输入,数据输出”工作方式,所有RF和IF调谐均可在集成电路内自动完成,因此具有很高的可靠性和极低的功耗。文中介绍了MICRF005的主要特点、结构原理和引脚功能,最后给出了它的应用电路。
- Abstract:
- The MICRF005 QwikRadioTM UHF transceiver is a single-chip OOK ,on-off keyed,transceiver IC for remote wireless applications.This device is a true single-chip,"antenna-indata-out"device.All RF and IF tuning are accomplished automatically within the IC, which eliminate manual tuning production costs and results in a highly reliable?,extremely low -cost solution for high-volume wireless applications.
