The TPIC6B273 is a monolithic, high-voltage,
medium-current, power logic octal D-type latch
with DMOS-transistor outputs designed for use in
systems that require relatively high load power.
The device contains a built-in voltage clamp on
the outputs for inductive transient protection.
Power driver applications include relays, solenoids,
and other medium-current or high-voltage
loads.
The TPIC6B273 contains eight positive-edgetriggered
D-type flip-flops with a direct clear input.
Each flip-flop features an open-drain power
DMOS-transistor output.
全部1条评论
