微处理器dsPIC33F在微机保护装置中的应用
消耗积分:5 | 格式:rar | 大小:885 | 2010-12-27
刘杰
分享资料个
数字信号处理器dsPIC33F集多通道高精度A/D转换、多通讯模式、看门狗、CMOS Flash技术等于一体,其内部可完成所有数据操作,实现总线不出芯片技术。将该处理器应用于微机保护装置,提出基于dsPIC33F微处理器的微机保护装置的设计方案,给出相应的接口电路与软件流程。该设计方案结构简单,性价比及可靠性高,开发周期短,具有一定的实用推广价值。所研制的微机保护装置现场运行效果良好。
Abstract:
 The dsPIC33F microprocessor has a plentiful interior resource which contains multi-channel,high precision A/D converters,multi-communication module,watchdog,CMOS Flash technology,and so on.All data manipulations is accomplished interiorly.What is more,it makes the technology that bus does not go beyond the chip comes into practice.The paper put forwards a design scheme based on dsPIC33F microprocessor.The scheme has the advantages of simple structure,high reliability and shortened exploitation cycle.What is more,it has definite practicality and reference.The microcomputer protection device has been put into operation with excellent effects.
评论(0)
发评论
下载排行榜
