MAX16031系统管理器可在焊接到应用电路板后进行编程设置,即只需储存未编程器件,而最新版本的配置信息可以在生产测试过程中写入器件。通过几项简单的测试可确保应用电路通过共享I2C总线进行硬件编程,并且在编程过程中为器件供电,并给出I2C总线的编程算法。
- Abstract:
- The MAX16031system monitors is programmed after being soldered to the application circuit board.This means that only unprogrammed devices need to be stocked,and that the latest version of the configuration information is written to the device during manufacturing test.A few simple measures,which are detailed in this application note,ensure that the ap-plication circuit allows the programming hardware to share the I2C or JTAG bus line and provides power for the device dur-ing programming.The programming algorithm is also provided for the I2Cbus.
