IP4281CZ10 pdf datasheet (ESD-
消耗积分:5 | 格式:rar | 大小:555 | 2008-10-30
吴藩
分享资料个
The IP4281CZ10 is designed for HDMI interface protection. The device includes high-level ElectroStatic Discharge (ESD) protection diodes for the TMDS signal lines.
All TMDS intra-pairs are protected by a special diode configuration offering a low line capacitance of only 0.7 pF. These diodes provide protection to downstream components from ESD voltages up to +-8 kV contact according to IEC 61000-4-2, level 4.
Features
Pb-free, RoHS compliant and free of Halogen and Antimony (dark green compliant)
ESD protection for HDMI and other LVDS data lines
All TMDS lines with integrated rail-to-rail clamping diodes for downstream ESD protection of +-8 kV according to IEC61000-4-2, level 4
Matched 0.5 mm trace spacing
TMDS lines with ≤ 0.05 pF matching capacitance between TMDS pairs
Line capacitance of only 0.7 pF for each channel
4-channel, 10-terminal Ultra-Thin Leadless Package (UTLP)
HDMI 1.3a compliant
评论(0)
发评论
下载排行榜
