MC14066 pdf datasheet
消耗积分:10 | 格式:rar | 大小:333 | 2008-11-07
分享资料个
The MC14066B consists of four independent switches capable of
controlling either digital or analog signals. This quad bilateral switch
is useful in signal gating, chopper, modulator, demodulator and
CMOS logic implementation.
The MC14066B is designed to be pin–for–pin compatible with the
MC14016B, but has much lower ON resistance. Input voltage swings
as large as the full supply voltage can be controlled via each
independent control input.
• Triple Diode Protection on All Control Inputs
• Supply Voltage Range = 3.0 Vdc to 18 Vdc
• Linearized Transfer Characteristics
• Low Noise — 12 nV//Cycle, f . 1.0 kHz typical
• Pin–for–Pin Replacement for CD4016, CD4016, MC14016B
• For Lower RON, Use The HC4066 High–Speed CMOS Device
评论(0)
发评论
下载排行榜
