ADS7841 pdf datasheet (12-Bit,
消耗积分:10 | 格式:rar | 大小:333 | 2008-12-19
王丽
分享资料个
The ADS7841 is a 4-channel, 12-bit sampling analogto-
digital converter (ADC) with a synchronous serial
interface. The resolution is programmable to either 8
or 12 bits. Typical power dissipation is 2mW at a
200kHz throughput rate and a +5V supply. The reference
voltage (VREF) can be varied between 100mV and
VCC, providing a corresponding input voltage range of
0V to VREF. The device includes a shutdown mode
which reduces power dissipation to under 15mW. The
ADS7841 is guaranteed down to 2.7V operation.
Low power, high speed, and on-board multiplexer
make the ADS7841 ideal for battery operated systems
such as personal digital assistants, portable multichannel
data loggers, and measurement equipment.
The serial interface also provides low-cost isolation
for remote data acquisition. The ADS7841 is available
in a 16-pin PDIP or a 16-lead SSOP package and is
guaranteed over the –40°C to +85°C temperature range.
评论(1)
发评论
qu123456 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%25CD%25F8%25D5%25BE%252C%2B%25C3%25E5%25B1%25B1%25BB%25B7%25C7%25F2%25D3%25E9%25C0%25D6%25C6%25BD%25CC%25A8B2024.cN%252C%25BE%25A3%25D6%25DD%25B7%25C0%25D2%25DF_93s.htm http://house.china.com.cn/sousou/%25C9%25CF%25CF%25C2%25B7%25D6%252C%2B%25C3%25E5%25B5%25E9%25B5%25CF%25CD%25FE%25B9%25FA%25BC%25CA%25D3%25E9%25C0%25D6B2024.cN_1s.htm http://house.china.com.cn/sousou/%25C0%25CF%25BD%25D6%252C%2B%25B9%25FB%25B8%25D2%25BD%25F0%25B6%25A6%25B9%25AB%25CB%25BEB2024.cN_37s.htm http://house.china.com.cn/sousou/%25CF%25D6%25BD%25F0%25CD%25F8%252C%2B%25C3%25E5%25B5%25E9%25B5%25CF%25CD%25FE%25B9%25FA%25BC%25CAB2024.cN_1s.htm http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%252C%2B%25C3%25E5%25B5%25E9%25BD%25F0%25B6%25A6%25B9%25FA%25BC%25CAB2024.cN%252C%25B3%25A3%25B5%25C2%25D2%25DF%25C7%25E9_3s.htm 收起回复
下载排行榜
全部1条评论
