NE5234/SA5234 pdf datasheet (M
消耗积分:3 | 格式:rar | 大小:333 | 2009-04-10
分享资料个
The NE/SA5234 is a matched, low voltage, high performance quad
operational amplifier. Among its unique input and output
characteristics is the capability for both input and output rail-to-rail
operation, particularly critical in low voltage applications. The output
swings to less than 50 mV of both rails across the entire power
supply range. The NE/SA5234 is capable of delivering 5.5 V
peak-to-peak across a 600 W load and will typically draw only
700 mA per amplifier. The bandwidth is 2.5 MHz and the 1% settling
time is 1.4 ms.
评论(0)
发评论
下载排行榜
