MAX11100 ,pdf(16-Bit, +5V, 200ksps ADC)
消耗积分:0 | 格式:pdf | 大小:2.4 MB | 2011-10-19
分享资料个
The MAX11100 low-power, 16-bit analog-to-digital converter(ADC) features a successive-approximation ADC,automatic power-down, fast 1.1Fs wake-up, and a highspeedSPI/QSPI™/MICROWIRE®-compatible interface.The MAX11100 operates with a single +5V analog supplyand features a separate digital supply, allowing directinterfacing with 2.7V to 5.25V digital logic.At the maximum sampling rate of 200ksps, the MAX11100typically consumes 2.45mA. Power consumption is typically12.25mW (VAVDD = VDVDD = +5V) at a 200ksps(max) sampling rate. AutoShutdown™ reduces supplycurrent to 140FA at 10ksps and to less than 10FA atreduced sampling rates.
MAX11100
评论(0)
发评论
下载排行榜
