The MAX5316 is a high-accuracy, 16-bit, serial SPI input,buffered voltage output digital-to-analog converter (DAC)in a 4mm x 5mm, 24-lead TQFN package. The devicefeatures Q1 LSB INL (max) accuracy and a Q0.25 LSBDNL (typ) accuracy over the temperature range of -40NCto +105NC.
