The MAX2687/MAX2694 low-noise amplifiers (LNAs) aredesigned for GPS L1, Galileo, and GLONASS applications.Designed in Maxim’s advanced SiGe process,the devices achieve high gain and low noise figurewhile maximizing the input-referred 1dB compressionpoint and the 3rd-order intercept point. The MAX2687provides a high gain of 17.8dB. The MAX2694 supplies11.6dB of gain while attaining higher linearity.The devices operate from a +1.6V to +3.6V single supply.The optional shutdown feature in the devices reducesthe supply current to less than 10FA. The devicesare available in a very small, lead-free, RoHS-compliant,0.86mm x 0.86mm x 0.65mm wafer-level package (WLP).
