The MAX16962 is a high-efficiency, synchronous stepdownconverter that operates with a 2.7V to 5.5V inputvoltage range and provides a 0.8V to 3.6V output voltagerange. The wide input/output voltage range and the abilityto provide up to 4A to load current make this deviceideal for on-board point-of-load and post-regulationapplications. The MAX16962 achieves -3.7%/+2.6% outputerror over load, line, and temperature ranges.
