The MAX3051 interfaces between the CAN protocolcontroller and the physical wires of the bus lines in acontroller area network (CAN). The MAX3051 providesdifferential transmit capability to the bus and differentialreceive capability to the CAN controller. The MAX3051is primarily intended for +3.3V single-supply applicationsthat do not require the stringent fault protectionspecified by the automotive industry (ISO 11898).
