MAX6620数据资料
消耗积分:0 | 格式:pdf | 大小:235 KB | 2013-01-16
刘明
分享资料个
The MAX6620 controls the speeds of up to four fansusing four independent linear voltage outputs. Thedrive voltages for the fans are controlled directly overthe I2C interface. Each output drives the base of anexternal bipolar transistor or the gate of a FET in highsidedrive configuration. Voltage feedback at the fan’spower-supply terminal is used to force the correct output
评论(0)
发评论
下载排行榜
