RDA5820 datasheet V1_3
消耗积分:1 | 格式:pdf | 大小:801KB | 2014-10-27
li3323
分享资料个
The RDA5820 is a single-chip broadcast FM transceiver with fully integrated synthesizer, IF selectivity and MPX decoder。 The chip uses the CMOS process,support multi-interface and require the least external component。 The package size is 4X4mm and is completely adjustment-free。 All these make it very suitable for portable devices。
评论(3)
发评论
唯木之 2020-08-11
0 回复 举报
有用 收起回复
you_man 2019-08-02
0 回复 举报
有用 收起回复
全部评论
下载排行榜
全部3条评论
