Verilog黄金指南
消耗积分:5 | 格式:rar | 大小:656 | 2009-08-03
分享资料个
The main body of this guide is divided into three main parts, each of
which is organised alphabetically. Each section is indexed by a key
term which appears prominently at the top of each page. Often you
can find the information you want by flicking through the guide
looking for the appropriate key term. If that fails, there is a full index
at the back.
Most of the information in this guide is organised around the Verilog
syntax headings, but there are additional special sections on Coding
Standards, Design Flow, Errors, Reserved Words and, after the main
alphabetical reference section, Compiler Directives, System Tasks
and Functions and Command Line Options.
If you are new to Verilog, you should start by reading A Brief
Introduction to Verilog, which follows overleaf.
评论(0)
发评论
下载排行榜
