AMC3202,pdf datasheet (1.5A 28
消耗积分:5 | 格式:rar | 大小:433 | 2009-08-27
百灵千岛酱
分享资料个
The AMC3202 is a 280kHz switching regulator with a
high efficiency, 1.5A integrated switch. The part operates over
a wide input voltage range, from 2.7V to 30V. The AMC3202
utilizes current mode architecture, which allows excellent load
and line regulation, as well as a practical means for limiting
current. Combining high frequency operation with a highly
integrated regulator circuit results in an extremely compact
power supply solution.
Build-in thermal protection to prevent the chip over heat damage.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
