The TSW4806 evaluation module (EVM), one of the new Texas Instruments (TI) low-cost evaluation tools, uses an LMK04806 dual-PLL clock-jitter cleaner and generator, providing a low cost, low-noise, portable clocking solution for use with TI's high-speed data converter EVMs. Together with the accompanying Labview-based Graphical User Interface (GUI), it is a complete clocking tool used with the other low-cost TI evaluation tools providing a complete system that captures and evaluates data samples from ADC EVM’s and generates test patterns to DAC EVM’s. The EVM's on-board EEPROM comes with several pre-programmed register settings so the board can begin running without using the GUI interface. The EEPROM provides the memory necessary for saving up to eight custom LMK04806 configuration settings. These settings are quickly loaded using on-board switches.
