LM25574/LM25574Q,pdf datasheet
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-29
贾桂林
分享资料个
The LM25574 is an easy to use SIMPLE SWITCHER® buck
regulator which allows design engineers to design and optimize
a robust power supply using a minimum set of components.
Operating with an input voltage range of 6 - 42V, the
LM25574 delivers 0.5A of continuous output current with an
integrated 750mΩ N-Channel MOSFET. The regulator utilizes
an Emulated Current Mode architecture which provides
inherent line regulation, tight load transient response, and
ease of loop compensation without the usual limitation of lowduty
cycles associated with current mode regulators. The
operating frequency is adjustable from 50kHz to 1MHz to allow
optimization of size and efficiency. To reduce EMI, a
frequency synchronization pin allows multiple IC’s from the
LM(2)557x family to self-synchronize or to synchronize to an
external clock. The LM25574 guarantees robustness with cycle-
by-cycle current limit, short-circuit protection, thermal
shut-down, and remote shut-down. The device is available in
a TSSOP-16 package. The LM25574 is supported by the full
suite of WEBENCH® On-Line design tools.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
