LM2662/LM2663,pdf datasheet (S
消耗积分:5 | 格式:rar | 大小:558 | 2009-09-29
李丽
分享资料个
The LM2662/LM2663 CMOS charge-pump voltage converter
inverts a positive voltage in the range of 1.5V to 5.5V to the
corresponding negative voltage. The LM2662/LM2663 uses
two low cost capacitors to provide 200 mA of output current
without the cost, size, and EMI related to inductor based converters.
With an operating current of only 300 μA and operating
efficiency greater than 90% at most loads, the LM2662/
LM2663 provides ideal performance for battery powered systems.
The LM2662/LM2663 may also be used as a positive
voltage doubler.
评论(0)
发评论
下载排行榜
