LP3883,pdf datasheet (3A Fast-
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-30
旧念
分享资料个
The LP3883 is a high-current, fast-response regulator which
can maintain output voltage regulation with minimum input to
output voltage drop. Fabricated on a CMOS process, the
device operates from two input voltages: Vbias provides
voltage to drive the gate of the N-MOS power transistor,
while Vin is the input voltage which supplies power to the
load. The use of an external bias rail allows the part to
operate from ultra low Vin voltages. Unlike bipolar regulators,
the CMOS architecture consumes extremely low quiescent
current at any output load current. The use of an
N-MOS power transistor results in wide bandwidth, yet minimum
external capacitance is required to maintain loop stability.
评论(0)
发评论
下载排行榜
