LP2966,pdf datasheet (Dual 150
消耗积分:3 | 格式:rar | 大小:555 | 2009-10-06
Petc
分享资料个
The LP2966 dual ultra low-dropout (LDO) regulator operates
from a +2.70V to +7.0V input supply. Each output delivers
150mA over full temperature range. The IC operates with
extremely low drop-out voltage and quiescent current, which
makes it very suitable for battery powered and portable
applications. Each LDO in the LP2966 has independent
shutdown capability. The LP2966 provides low noise performance
with low ground pin current in an extremely small
MSOP-8 package (refer to package dimensions and connection
diagram for more information on MSOP-8 package). A
wide range of preset voltage options are available for each
output. In addition to the voltage combinations listed in the
ordering information table, many more are available upon
request with minimum orders. In all, 256 voltage combinations
are possible.
评论(0)
发评论
下载排行榜
