LM5106,pdf datasheet (100V Hal
消耗积分:5 | 格式:rar | 大小:552 | 2009-10-06
贾埃罗
分享资料个
The LM5106 is a high voltage gate driver designed to drive
both the high side and low side N-Channel MOSFETs in a
synchronous buck or half bridge configuration. The floating
high side driver is capable of working with rail voltages up to
100V. The single control input is compatible with TTL signal
levels and a single external resistor programs the switching
transition dead-time through tightly matched turn-on delay
circuits. The robust level shift technology operates at high
speed while consuming low power and provides clean output
transitions. Under-voltage lockout disables the gate driver
when either the low side or the bootstrapped high side
supply voltage is below the operating threshold. The LM5106
is offered in the MSOP-10 or thermally enhanced 10-pin LLP
plastic package.
评论(0)
发评论
下载排行榜
