LM8272,pdf datasheet (RRIO, Hi
消耗积分:3 | 格式:rar | 大小:454 | 2009-10-07
分享资料个
The LM8272 is a Rail-to-Rail input and output Op Amp which
can operate with a wide supply voltage range. This device
has high output current drive, greater than Rail-to-Rail input
common mode voltage range, unlimited capacitive load drive
capability while requiring only 0.95mA/channel supply current.
It is specifically designed to handle the requirements of
flat panel TFT panel VCOM driver applications as well as
being suitable for other low power, and medium speed applications
which require ease of use and enhanced performance
over existing devices.
评论(0)
发评论
下载排行榜
