LM4880,pdf datasheet (Dual 250
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-09
刘敏
分享资料个
The LM4880 is a dual audio power amplifier capable of
delivering typically 250mW per channel of continuous average
power to an 8Ω load with 0.1% THD+N using a 5V
power supply.
Boomer audio power amplifiers were designed specifically to
provide high quality output power with a minimal amount of
external components using surface mount packaging.
Since the LM4880 does not require bootstrap capacitors or
snubber networks, it is optimally suited for low-power portable
systems.
评论(0)
发评论
下载排行榜
