LM4902,pdf datasheet (265mW at
消耗积分:5 | 格式:rar | 大小:556 | 2009-10-09
刘芳
分享资料个
The LM4902 is a bridged audio power amplifier capable of
delivering 265mW of continuous average power into an 8W
load with 1% THD+N from a 3.3V power supply.
Boomer® audio power amplifiers were designed specifically
to provide high quality output power from a low supply voltage
while requiring a minimal amount of external components.
Since the LM4902 does not require output coupling
capacitors, bootstrap capacitors or snubber networks, it is
optimally suited for low-power portable applications.
The LM4902 features an externally controlled, low power
consumption shutdown mode, and thermal shutdown protection.
评论(0)
发评论
下载排行榜
