The ADG751 is a low voltage SPST (single pole, single throw)
switch. It is constructed in a T-switch configuration, which
results in excellent Off Isolation while maintaining good frequency
response in the ON condition.
High off isolation and wide signal bandwidth make this part
suitable for switching RF and video signals. Low power consumption
and operating supply range of +1.8 V to +5.5 V make
it ideal for battery powered, portable instruments.
The ADG751 is designed on a submicron process that provides
low power dissipation yet gives high switching speed and low on
resistance. This part is a fully bidirectional switch and can handle
signals up to and including the supply rails.
The ADG751 is available in 6-lead SOT-23 and 8-lead mSOIC
packages.
