The ADG714 is a CMOS, octal SPST (single-pole, single-throw) switch controlled via a 3-wire serial interface. On resistance is closely matched between switches and very flat over the full signal range. Each switch conducts equally well in both directions and the input signal range extends to the supplies. Data is written to these devices in the form of 8 bits
下载资料需要登录,并消耗一定积分。
