TIAWR1243汽车77和79GHz FMCW收发器解决方案
TI公司的AWR1243是单片77GHz和79GHz频率调制连续波(FMCW)收发器,具有基于分数N PLL的超精密啁啾引擎,简化了汽车雷达传感器在76-81GHz的实现方案。采用低功耗45nm RFCMOS工艺,单片实现了内置PLL和A2D转换器的3TX,4RX系统.TX发送功率12dBm,RX噪音15dB (76-77GHz), 16dB(77-81GHz),1MHz时的相位噪音–94 dBc/Hz (76-77 GHz),–91 dBc/Hz (77 - 81 GHz),内置了校准和自测试等功能。主要用在自动高速公路驾驶,自动紧急刹车和自适应巡航控制。本文介绍了AWR1243主要特性,功能框图,短中远距离雷达框图,参考电路,以及AWR1443 BoosterPack™评估板主要特性,框图,电路图,材料清单和PCB设计图。
The AWR1243 device is an integrated single-chip FMCW transceiver capable of operation in the 76- to 81-GHz band. The device enables unprecedented levels of integration in an extremely small form factor. AWR1243 is an ideal solution for low power, self-monitored, ultra-accurate radar systems in the automotive space.
