高低侧驱动器IR2213(S)PBF
消耗积分:0 | 格式:rar | 大小:1.19 MB | 2017-09-11
分享资料个
  The IR2213(S) is a high voltage, high speed power MOSFET and IGBT driver with independent high and low side referenced output channels. Proprietary HVIC and latch immune CMOS technologies enable ruggedized monolithic construction. Logic inputs are compatible with standard CMOS or LSTTL outputs, down to 3.3 V logic. The output drivers feature a high pulse current buffer stage designed for minimum driver cross-conduction. Propagation delays are matched to simplify use in high frequency applications. The floating channel can be used to drive an N-channel power MOSFET or IGBT in
高低侧驱动器IR2213(S)PBF
评论(0)
发评论
下载排行榜
