The TLE4906 is a high precision Hall effect switch with highly accurate switching thresholds for operating temperatures up to 150°C.
2.7V to 24V supply voltage • Operation from unregulated power supply • High sensitivity and high stability of the magnetic switching points • High resistance to mechanical stress by Active Error Compensation • Reverse battery protection (-18V) • Superior temperature stability • Peak temperatures up to 195°C without damage • Low jitter (typ. 1µs) • High ESD performance (± 6kV HBM) • Digital output signal • SMD package SC59 (SOT23 compatible) - (TLE4906K)) • Leaded package PG-SSO-3-2 - (TLE4906L)
Target applications for TLE4906 are all automotive applications which require a high precision Hall switch for position sensing with a operating temperature range from -40°C to +150°C.
