项目简介:
JRDB:一个对FMDB进行类Hibernate封装的iOS库,支持Objective-C 和 Swift。
Deion
使用分类的模式,模仿Hibernate,对FMDB进行简易封装
支持pod 安装 『pod ‘JRDB’』,Podfile需要添加 use_framework!
使用协议,不用继承基类,对任意NSObject可以进行入库操作
支持swift 和 Objective-C
支持数据类型:基本数据类型(int,double,等),String,NSData,NSNumber,NSDate
注:Swift的基本数据类型,不支持Option类型,既不支持Int?Int!等,对象类型支持Option类型
Installation(安装)
use_frameworks!
pod ‘JRDB’
@import JRDB;
Usage
Save(保存)
Objective-C
Person *p = [[Person alloc] init];
p.a_int = 1;
p.b_unsigned_int = 2;
p.c_long = 3;
p.d_long_long = 4;
p.e_unsigned_long = 5;
p.f_unsigned_long_long = 6;
p.g_float = 7.0;
p.h_double = 8.0;
p.i_string = @“9”;
p.j_number = @10;
p.k_data = [NSData data];
p.l_date = [NSDate date];
[p jr_save];
Swift
Swift中需要入库的类需要继承NSObject(使用到runtime)
The Object that you want to persistent should inherit from NSObject
let p = Person()
p.name = “name”
p.age = 10
p.birthday = NSDate()
p.jr_save()
Update(更新)
Person *p = [Person jr_findAll].firstObject;
p.name = @“abc”;
[p jr_update columns:nil];
column: 需要更新的字段名,传入空为全量更新
Delete(删除)
[p jr_delete];
Select(查找)
常规查找
Person *p = [Person jr_findByPrimaryKey:@“111”];
NSArray *list = [Person jr_findAll];
NSArray *list1 = [Person jr_findAllOrderBy:@“_age” isDesc:YES];
条件查询
NSArray *condis = @[
[JRQueryCondition condition:@“_l_date 《 ?” args:@[[NSDate date]] type:JRQueryConditionTypeAnd],
[JRQueryCondition condition:@“_a_int 》 ?” args:@[@9] type:JRQueryConditionTypeAnd],];
NSArray *arr = [Person jr_findByConditions:condis
groupBy:@“_room”
orderBy:@“_age”
limit:@“ limit 0,13 ”
isDesc:YES];
SQL
NSString *sql = @“select * from Person where age = ?”;
NSArray *list = [Person jr_executeSql:sql args:@[@10]];
Other(其他)
协议:JRPersistent
@protocol JRPersistent @required
- (void)setID:(NSString * _Nullable)ID;
- (NSString * _Nullable)ID;
@optional
* 返回不用入库的对象字段数组
* The full property names that you want to ignore for persistent
* @return array
+ (NSArray * _Nullable)jr_excludePropertyNames;
* 返回自定义主键字段
* @return 字段全名
+ (NSString * _Nullable)jr_customPrimarykey;
* 返回自定义主键值
* @return 主键值
- (id _Nullable)jr_customPrimarykeyValue;
@end
主键
默认每个Object的主键为ID, UUID字符串。
可以实现 jr_customPrimarykey 以及 jr_customPrimarykeyValue 方法,自定义主键。
默认NSObject分类实现
@interface NSObject (JRDB) (。。.methods)
@end
JRDBMgr
@interface JRDBMgr : NSObject
@property (nonatomic, strong) FMDatabase *defaultDB;
+ (instancetype)shareInstance;
+ (FMDatabase *)defaultDB;
- (FMDatabase *)createDBWithPath:(NSString *)path;
- (void)deleteDBWithPath:(NSString *)path;
* 在这里注册的类,使用本框架的数据库将全部建有这些表
* @param clazz 类名
- (void)registerClazzForUpdateTable:(Class)clazz;
- (NSArray *)registedClazz;
* 更新默认数据库的表(或者新建没有的表)
* 更新的表需要在本类先注册
- (void)updateDefaultDB;
- (void)updateDB:(FMDatabase *)db;
@end
JRDBMgr持有一个默认数据库(~/Documents/jrdb/jrdb.sqlite),任何不指定数据库的操作,都在此数据库进行操作。默认数据库可以自行设置。
Method
在JRDBMgr中注册的类,可以使用
-(void)updateDB:(FMDatabase *)db
进行统一更新或者创建表。
Table Operation(表操作)
Create(建表)
// FMDatabase+JRDB 方法
[[JRDBMgr defaultDB] createTable4Clazz:[Person class]];
[Person jr_createTable];
// 删除原有的表,重新创建
[[JRDBMgr defaultDB] truncateTable4Clazz:[Person class]];
[Person jr_truncateTable];
//保存时,若发现没有表,将自动创建
[person jr_save];
Update 【更新表】
[[JRDBMgr defaultDB] updateTable4Clazz:[Person class]];
[Person jr_updateTable];
更新表时,只会添加不存在的字段,不会修改字段属性,不会删除字段,若有需要,需要自行写sql语句进行修改
Drop(删表)
[[JRDBMgr defaultDB] dropTable4Clazz:[Person class]];
[Person jr_dropTable];
Thread Operation(线程操作)
多线程操作使用FMDB自带的 FMDatabaseQueue
[person jr_saveWithComplete:^(BOOL success) {
NSLog(@“%d”, success);
任何带complete block的操作,都将放入到FMDatabaseQueue进行顺序执行
注:所有需要立刻返回结果,或者影响其他操作的数据库操作,都建议放在主线程进行更新,大批量更新以及多线程操作数据库时,请使用带complete block的操作。
MoreUsage
查看FMDatabase+JRDB.h
项目地址:https://github.com/scubers/JRDB(觉得可以的话就麻烦星一下呗~~~)
第一次写这种东西,可能已经Github上已经有了很多类似的东西,如果有不足之处还请指教。
