ISL54100A pdf datasheet
消耗积分:5 | 格式:rar | 大小:555 | 2008-08-05
郑成枝
分享资料个
The ISL54100A, ISL54101A, ISL54102A are highperformance TMDS (Transition Minimized Differential Signaling) timing regenerators and multiplexers. The receiver contains a programmable equalizer and a clock data recovery (CDR) function for each of the 3 TMDS pairs in an HDMI or DVI signal. The TMDS data outputs of the ISL5410xA are regenerated and perfectly aligned to the regenerated TMDS clock signal, creating an extremely clean, low-jitter DVI/HDMI signal that can be easily decoded by any TMDS receiver.
评论(0)
发评论
下载排行榜
