Bipolar High-repetition-rate P
消耗积分:3 | 格式:rar | 大小:344 | 2010-05-22
张杰
分享资料个
Abstract: The pulser designed is mainly used for producing corona plasma in waste water treatment system. Also its application in research on dielectric film electrical properties will be discussed. The pulser consists of a variable DC power source for high voltage supply, two graded capacitors for energy storage and the rotating spark gap used as switches. The key part is the multiple-electrode rotating spark gap switch(MER-SGS), which greatly favors the wide range modulation of pulse repetition rate, long width and short rise time of the pulse, electrical field distortion, recovery of the gap insulation strength, insulation design, the life of the switch, etc. The voltage of the output pulses switched by the MER-SGS is in the order
of 1kV-50kV with a pulse rise time of less than 10ns, a pulse duration of 1-500us determined by the load, a pulse repetition rate of 1-2k PPs variable, an energy of 1.25-125 J per pulse and a average power of up to 10-50kW have been achieved. The high-est pulse repetition rate is determined by the highest revolution of the driver motor and the electrodes number of MER-SGS. Even higher voltage and energy can be switched by employing N2 as the insulation material and adjusting the gas pressure or enlarging the size of MER-SGS to guarantee enough insulation level.
关键词: 电晕等离子体; 废水处理; 高重复频率高压脉冲发生器; 多电极旋转火花隙开关
Key Words: Keywords: corona plasma, waste water treatment, bipolar high-repetition rate high-voltage pulser, multiple-electrode rotating spark gap switch (MER-SGS).
评论(0)
发评论
下载排行榜
