ADS8317,pdf ( High-Speed, 2.7V
消耗积分:5 | 格式:rar | 大小:1285 | 2010-06-03
分享资料个
The ADS8317 is a 16-bit, sampling, analog-to-digital (A/D) converter specified for a supply voltage range from 2.7V to 5.5V. It requires very little power, even when operating at the full data rate. At lower data rates, the high speed of the device enables it to spend most of its time in the power-down mode. For example, the average power dissipation is less than 0.2mW at a 10kHz data rate.
The ADS8317 offers excellent linearity and very low noise and distortion. It also features a synchronous serial (SPI/SSI-compatible) interface and a differential input. The reference voltage can be set to any level within the range of 0.1V to VDD/2.
Low power and small size make the ADS8317 ideal for portable and battery-operated systems.
评论(0)
发评论
下载排行榜
