DAC8565,pdf(16-Bit, Quad Chan,
消耗积分:5 | 格式:rar | 大小:1642 | 2010-06-09
分享资料个
The DAC8565 is a low-power, voltage-output, four-channel, 16-bit digital-to-analog converter (DAC). The device includes a 2.5V, 2ppm/°C internal reference (enabled by default), giving a full-scale output voltage range of 2.5V. The internal reference has an initial accuracy of 0.004% and can source up to 20mA at the VREFH/VREFOUT pin. The device is monotonic, provides very good linearity, and minimizes undesired code-to-code transient voltages (glitch). The DAC8565 use a versatile 3-wire serial interface that operates at clock rates up to 50MHz. It is compatible with the standard SPI™, QSPI™, Microwire™, and digital signal processor (DSP) interfaces.
The DAC8565 incorporates a power-on-reset circuit that ensures the DAC output powers up at either zero-scale or midscale until a valid code is written to the device.
评论(0)
发评论
下载排行榜
