AFE0064,pdf(64 Channel Analog
消耗积分:5 | 格式:rar | 大小:582 | 2010-06-11
overheat
分享资料个
The AFE0064 is a 64 channel analog front end designed to suit the requirements of flat panel detector based digital X-ray systems.
The device includes 64 integrators, a PGA for full scale charge level selection, correlated double sampler, 64 as to 2 multiplexer, and two differential output drivers.
Hardware selectable Integration polarity allows integration of a positive or negative charge and provides more flexibility in system design. In addition, the device features TFT (Thin Film Transistor from Flat Panel Detector) charge injection compensation. This feature helps maximize the usable signal charge range of the device.
The nap feature enables substantial power saving. This is especially useful for power saving during long X-ray exposure periods.
评论(0)
发评论
下载排行榜
