PCM4222,pdf(High-Performance,
消耗积分:5 | 格式:rar | 大小:1167 | 2010-06-13
郝埃连
分享资料个
The PCM4222 is a high-performance, two-channel analog-to-digital (A/D) converter designed for use in professional audio applications. Offering outstanding dynamic performance, the PCM4222 supports 24-bit linear PCM, 1-bit Direct Stream Digital (DSD), and 6-bit modulator data outputs. The supported output formats make the PCM4222 ideal for digital audio recording and processing applications. The multi-bit modulator output adds versatility, allowing customers to design their own digital decimation filter and processing hardware. The on-chip, linear phase decimation filtering engine supports Classic and Low Group Delay filter responses, allowing optimization for either studio or live sound applications.
The PCM4222 includes three PCM sampling modes, supporting output sampling rates from 8kHz to 216kHz.
评论(0)
发评论
下载排行榜
