TLV320AIC3105,pdf(Low Power St
消耗积分:5 | 格式:rar | 大小:1401 | 2010-06-25
靓仔峰
分享资料个
The TLV320AIC3105 is a low-power stereo audio codec with multiple single-ended inputs and and a stereo headphone amplifier. The output stages are programmable in single-ended or fully differential configurations. Extensive register-based power control is included, enabling stereo 48-kHz DAC playback as low as 14 mW from a 3.3-V analog supply, making it ideal for portable battery-powered audio and telephony applications.
The record path of the TLV320AIC3105 contains integrated microphone bias, digitally controlled stereo microphone preamplifier, and automatic gain control (AGC), with mix/mux capability among the multiple analog inputs. Programmable filters are available during record which can remove audible noise that can occur during optical zooming in digital cameras.
评论(0)
发评论
下载排行榜
