TLV320AIC3110,pdf(Low-Power Au
消耗积分:5 | 格式:rar | 大小:1445 | 2010-06-25
张文
分享资料个
The TLV320AIC3110 is a low-power, highly integrated, high-performance codec which supports stereo audio DAC, and mono audio ADC.
The TLV320AIC3110 features a high-performance audio codec with 24-bit stereo playback and monaural record functionality. The device integrates several analog features, such as a microphone interface, headphone drivers, and speaker drivers. The digital audio data format is programmable to work with popular audio standard protocols (I2S, left/right-justified) in master, slave, DSP, and TDM modes. Bass boost, treble, or EQ can be supported by the programmable digital-signal processing blocks (PRB). An on-chip PLL provides the high-speed clock needed by the digital-signal processing block.
评论(0)
发评论
下载排行榜
