SN54HC05, SN74HC05,pdf(HEX INV
消耗积分:3 | 格式:rar | 大小:613 | 2010-07-13
分享资料个
The ’HC05 devices contain six independent inverters. They perform the Boolean function Y = A\ in positive logic. The open-drain outputs require pullup resistors to perform correctly. They may be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
