SN74ALS35A,pdf(Hex Noninverter
消耗积分:2 | 格式:rar | 大小:405 | 2010-07-16
李丽
分享资料个
The SN74ALS35A contains six independent noninverters with open-collector outputs. They perform the Boolean function Y = A. The open-collector outputs require pullup resistors to perform correctly. These outputs may be connected to other open-collector outputs to implement active-low wired-OR or active-high wired-AND functions. Open-collector devices are often used to generate higher VOH levels.
The SN74ALS35A is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
